Activity › Forums › Adobe Encore DVD › Black lines when importing PP CS5 1440×1080 sequence to Encore CS5
  • Black lines when importing PP CS5 1440×1080 sequence to Encore CS5
    Posted by Justin Martin on January 31, 2012 at 12:11 pm
    I have a High Def sequence that I created in Premiere Pro CS5 and I import it to Encore CS5 and it has black lines on the sides. I read through some of the posts on how to fix it but it’s unclear if it gets adjusted in PP or Encore and how to properly adjust it. Any quick fixes?
    Also is there a way to make one Encore project then save as blu ray or DVD? I want to make both formats and not two projects for the same. I suspect I know the answer and I have to make two projects.
    Thx for the assistance!
    Justin Martin replied 14 years, 8 months ago 1 Member · 2 Replies
  • Justin Martin
    January 31, 2012 at 7:48 pm
    As an FYI – I’m not sure how to adjust export settings if your using dynamic link. I don’t want to export as make a new file but use the sequence and link it into encore. So I’m not sure how to make the adjustments in the sequence not the export.
  • Justin Martin
    February 2, 2012 at 2:34 pm
    Nevermind I figured it out.
