Activity Forums Adobe Premiere Pro Black line in the bottom of the video (MJPEG codec)
  • Black line in the bottom of the video (MJPEG codec)
    Posted by Marina Cotrim on July 27, 2017 at 2:47 pm
    Hello everyone,
    I’m trying to edit a video in Premiere CC, but when I view it in the monitors, there is a black line of 1 px height in the bottom of the image. When I scale de image, the line goes away.
    What is weird is that when I view the same video on VLC, there is no black line.
    I would appreciate any toughts that might help me getting rid of this line (without the scaling).
    Media Info:
    Format : AVI
    Format/Info : Audio Video Interleave
    Format profile : OpenDML
    File size : 2.20 GiB
    Duration : 5mn 58s
    Overall bit rate : 52.7 Mbps
    Writing library : Livestream Avi file writer
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 5mn 58s
    Bit rate : 51.2 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Original height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Interlaced
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.824
    Time code of first frame : 11:44:57:00 / 11:44:57:00
    Time code source : Adobe tc_A / Adobe tc_O
    Stream size : 2.14 GiB (97%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 5mn 58s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 65.7 MiB (3%)
    Alignment : Aligned on interleaves
    Interleave, duration : 33 ms (1.00 video frame)
    Interleave, preload duration : 33 ms
    Thank you!
    Ann Bens replied 9 years, 1 month ago 2 Members · 3 Replies
  • Ann Bens
    July 28, 2017 at 1:46 pm
    Does it show on export?
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Marina Cotrim
    July 28, 2017 at 2:39 pm
    Hi, Ann,
    Yes, it does…
  • Ann Bens
    July 28, 2017 at 5:48 pm
    might be a codec issue.
    Just scale it up one pixel.
