Activity Forums VEGAS Pro Black IRE level confusion
  • Black IRE level confusion
    Posted by Dale Spetz on November 10, 2007 at 11:37 pm
    I am confused by Vegas, apparently useing 0 RGB for its Black level. It was my understanding that in the digital world, 16 RGB equaled 0 IRE.
    So, when I fade to black, in Vegas8, the IRE level drops below 0.
    Everything else that I have is set between 16 to 235 RGB, which I believe equates to 0 to 100 IRE.
    Is there a way to set Vegas8’s internal black level to 16 RGB?
    Dale Spetz replied 18 years, 10 months ago 4 Members · 4 Replies
  • Rick Mac
    November 11, 2007 at 12:58 am
    The scope in Vegas can be set to different configurations.
    Look in the Vegas help file for an explination of the scope
    settings. How you set them depends on several variables such as your hardware and codec used.
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Mike Kujbida
    November 11, 2007 at 2:18 am
    Have a look at Glenn Chan’s article The 7.5 IRE Setup Problem and see if it helps to clear up the confusion.
  • Rob Mack
    November 11, 2007 at 4:57 am
    There’s no setting. In some cases it’s appropriate for fades to black to go that low, otherwise the workaround is to place generated media on a track below everything else and set the black of that media at 16.
  • Dale Spetz
    November 11, 2007 at 1:05 pm
    I have been useing clips of Generated Media (set at 16), to fade into, to accomplish “fades to black”, as a workaround. It never occured to me to simply place the entire bottom track at 16-Black. Great tip!
    If there is no way to set the Vegas default Black to 16, then this seems like the way to go.
    I will also have to letterbox a 16×9 to a 4×3, again keeping the black top/bottom borders at 16 (0 IRE). I don’t believe that the Broadcast Filter will hold those borders to 0 IRE (though it will on the actual clips), so laying the 16×9 over a black bottom track of 16, again, may be the way to go.
    Thank you, all, for your input.
