Activity Forums VEGAS Pro “black frames”
  • “black frames”
    Posted by Yuriy Niksych on December 6, 2009 at 9:11 am
    right, I rendered my 3ds max animation as a targa sequence, upon importing it to vegas I noticed that in the space of this 10 second animation some black frames would show up. I rechecked the tga sequence and there were no black frames in it so it seems vegas is the cause, how do I fix it?
    Dale Spetz replied 16 years, 9 months ago 3 Members · 2 Replies
  • John Rofrano
    December 6, 2009 at 3:02 pm
    How did you import? Did you use File | Import | Media and select Import as image sequence? I have seen a bug in Vegas where I get occasional black frames on photo montages. I haven’t figure out why or have a reproducible test case to send to Sony but I have seen it in my own work. I usually re-render that small section and place it on a track above where the black frames show up and together the who thing is fine. This may be a workaround for you as well if the black frames are consistently in the same place. Maybe if your image sequence is small enough to send to Sony you could send it to them as a test case.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dale Spetz
    December 6, 2009 at 6:52 pm
    I have also seen the mysterious “black frames” appear, from time to time, when rendering. Often at the same spot. But, I also do not get them consistently, so I cannot reproduce the problem.
    Veg9c-64bit
