Black frames at the beginning of some AVCHD clips in project imported from Premiere Pro
Howdy. I’m using After Effects CC on OSX and doing some effects work on AVCHD footage. There’s an annoying problem where black frames will show up at the beginning of some clips, always between two clips. You can extend the preceding clip past the black frame, but I don’t want to disrupt edit timing to fix the issue. To add, this is with clips that still have footage prior to their “in” edits, so it’s not an issue of it being the very beginning of the file itself and not having anything to display.
Anyone have any ideas? I do have a bit of a deadline and I do not wish to lose weeks converting my hundreds of GBs of footage into dnxhd/similar format.
