Activity Forums Apple Final Cut Pro black flashes
  • black flashes
    Posted by David Mayer on May 29, 2021 at 7:48 pm
    In many years this is a first. Media in timeline is flashing on and off – alternating good frames with black ones. About half and half, no pattern, very often one frame on, one frame off. So, of the 29 frames in one second, maybe 15 normal and 14 black. Canon C-300, AVCHD from the SD card converted to ProRes 422 using EditReady. Exact same workflow I have used 1,000 times – nothing different. Any ideas?
    Joe Marler replied 5 years, 3 months ago 2 Members · 1 Reply
  • Joe Marler
    May 30, 2021 at 12:41 pm
    How do those media files look at each stage of the offload, conversion and import sequence?
    If you play the original camera media file in Quicktime Player or VLC, what does it look like?
    What about those same files played in Quicktime or VLC after conversion by EditReady but before import to FCP?
