Activity Forums DVD Authoring Black flash coming out of transistion (CS4 DVD PAL)
  • Black flash coming out of transistion (CS4 DVD PAL)
    Posted by Matt Stoddart on February 23, 2011 at 10:43 am
    I created 50 frames transistions between the menus, I encoded the transistions at 7CBR, 2M/12N frame setting.
    When I built the project to a folder and viewed it all the transistions looked fine, when I burnt the project to a DVD+R9 things went pair shaped, playback on DVD players varied.
    1) PS3: Full frame black flash before the transistion settled back into the menu on half of the transistion. (3 fine, 3 black flash)
    2) Midrange Sony player, same as PS3
    3) Bargain basement DVD player, played all transistion fine.
    I bumped into this problem when I first started using CS4 and read somewhere on this forum that the length of your transistion has to be evenly divisible by your m-frame setting, which solved the problem then.
    Any ideas why some worked and some didn’t? all exactly the same duration.
    Thanks in advance.
    Matt Stoddart replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
