Activity Forums Apple Motion Black dots in my motion graphics when I put it on top of Canon Footage
  • Black dots in my motion graphics when I put it on top of Canon Footage
    Posted by Lorenzo Escalante on January 14, 2011 at 1:00 pm
    Hello All,
    First and foremost let thank you guys for all the help you have provided me in my young career as a shooter and an editor….so thank you in advance…
    Okay so heres the problem…I have been using Apple Motion 4 to create motion graphics with success…but when I export…as Pro Res 4444 and import into my final cut than layer it on top of the clip I am trying to use….there are black dots!! that can be seen around the graphic…why is this happening….
    oh yeah..the canvas I am using is XDCAM422 24p
    and the footage is Apple pro res 422 HQ from a Canon 7D and 5D….
    Here is a basic example of my problem…
    https://vimeo.com/16682121
    it happens from about 0:10 to 0:18 roughly…please help…
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Sacha Thomas replied 15 years, 8 months ago 3 Members · 9 Replies
  • 9 Replies
  • Sacha Thomas
    January 14, 2011 at 3:39 pm
    I don’t think the dots are particularly distracting, The first time I watched it I didn’t even think they were an artifact of the compression process but rather part of the title effect. That said…
    What happens when you place the same title on another background? Dark vs. light background…you might see a hint to the solution.
    I suspect the problem may be related to the colorspace but my understanding of colorspace theory is a bit limited. I suggest this because you are going from 422 to 4444. The black specks may be caused by a lack of color info at those pixels (those pixels are out of gamut) due to the overlap of the colorspaces.
    You might want to ask something along those lines in a forum frequented by colorists (I hesitate to suggest the Apple Color forum, since it is technically off-topic)
    Can anyone on this forum confirm this?
    You could try exporting as a 422 colorspace to test this idea.
    I am curious why you have Dave Chappelle as Rick James when Tribe mentions Rick James. I just thought I would point that out in case it was an oversight.
    A suggestion-you might consider putting the individual rappers names on screen since they have aged since most of us were watching their videos. 😉
    Good luck. Hopefully someone with more colorspace experience can shed some light on this. Cheers!
  • Jeff Greenberg
    January 14, 2011 at 7:18 pm
    Have you tried skipping the export process and putting the motion file directly in FCP?
    Best,
    Jeff G
  • Lorenzo Escalante
    January 16, 2011 at 12:25 pm
    haha comedic purposes…I was trying to be funny…
  • Lorenzo Escalante
    January 16, 2011 at 12:26 pm
    I have not….can you stilll do that in Motion 4?
  • Jeff Greenberg
    January 16, 2011 at 3:09 pm
    You’ve been able to do that since Motion 2. Try it and see if it helps.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Lorenzo Escalante
    January 19, 2011 at 10:54 am
    I know this is a really dumb question…but I’ve tried searching it online and I have also tried the help option on the top bar….I have found no answer…
    How do I send my Motion project into FCP? -_-
  • Lorenzo Escalante
    January 19, 2011 at 11:05 am
    okay figured it out…just put the motion file into FCP…hahaha got it!….but should it also….bring in the audio as well…because mine is not doing it…
  • Jeff Greenberg
    January 19, 2011 at 2:03 pm
    No. No audio back from motion unless it came from a ‘send’ in fcp. 🙁
    Best,
    Jeff G
  • Sacha Thomas
    January 21, 2011 at 3:18 pm
    Could this be caused by the blend mode?
