Activity Forums DaVinci Resolve Black Border around R3D renders
  • Black Border around R3D renders
    Posted by Brandon Thomas on September 9, 2011 at 12:56 pm
    Often when i render R3D material out of Resolve, i’ll get a 1 or 2 pixel black border around my image. If i scale the image up a little, it gets rid of it.
    Is this something to do with debayer settings or anything like that? or maybe the automatically scale to fit isn’t behaving properly?
    is the best solution to just scale everything up slightly? anyone else experiencing this?
    Resolve 8 (latest update), Mac Pro 8×2.66, 10.6.8, 24gb Ram, Quadro 4000 GUI, Cubix-2x Quadro 4000 GPU, Red Rocket, LTO HBA-Decklink 3D+, Raid HBA
    Blase Theodore replied 15 years ago 5 Members · 4 Replies
  • Kevin Cannon
    September 9, 2011 at 2:10 pm
    Yeah, this is such an egregious problem that I’m surprised it doesn’t come up on this board all the time. I’d also be curious for an answer but I’ve noticed the problem goes away by scaling up on the output scaling like you suggested, or selecting “center crop with no resizing” on your input options and then the appropriate half-res decoder setting…
    It seems like it shouldn’t be that hard for the Resolve scaling to protect the edges… and it really seems to happen all the time with the “scale entire image to fit” setting.
    KC
    prehistoricdigital.com
    hardworkingpixels.com
  • Vladimir Kucherov
    September 9, 2011 at 2:14 pm
    Make sure “automatic blanking” is off in the format tab – I have no idea what’s going on with that but having that on auto seems to be what’s causing the border sometimes.
  • Chris Hall
    September 9, 2011 at 3:39 pm
    Yeah I’ve had the same issue with the .r3d’s and the black border. I always add an output scale of 1.002 on zoom to correct for the problem… but shouldn’t need to do that. Its a bug.
    Chris Hall
    Colorist – Basher Films
    Pasadena, CA
  • Blase Theodore
    September 9, 2011 at 3:50 pm
    Posted same issue a while ago…
    Here you go..
    Solution from Rohit:
    Source blanking in format page set it to off.
