Activity › Forums › Adobe Premiere Pro › Black bar showing up at bottom of screen after render
  • Black bar showing up at bottom of screen after render
    Posted by David Geary on December 15, 2012 at 10:16 pm
    I am editing RED Epic footage. It was shot 5K WS (5120×2160) and I am editing it in Premiere Pro CS6 (6.0.1) with my sequence settings the same as shot (5120×2160). Everything worked okay until I added a transparent video track the length of the project to add a timecode counter for post. When I rendered there is now a black bar at the bottom of the screen. I can go into motion – postition settings and change it from 2560.0 1080.0 to 2560.0 1081.0 and it will move down and cover so it appears either the aspect has changed or it has shifted. I have deleted the transparent video track but that does not help.
    Whenever I drag a new clip in, it will show correctly without the bar. I have tried removing effects, etc but it does not affect the bar. I have seen this on another project, any ideas on what is happening? Here’s a screen capture to give you an idea…
    Thanks.
    Brendon Costello replied 11 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • David Geary
    December 15, 2012 at 11:02 pm
    Upon further examination, it appears to be a very slight aspect shift when rendering.
  • Angelo Lorenzo
    December 15, 2012 at 11:45 pm
    In File > Export, look in the upper left of the window. For both source and output tabs on the Export window, check out your crop and scale settings.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • David Geary
    December 16, 2012 at 3:09 am
    I checked – everything looks correct. (scale to fit, no crop, etc). The issue is definitely in the sequence as I can see the thin black bar in the preview window when exporting. When I drag a new clip in, the bar is not present and the bar at the top of the sequence is yellow. When I render (Sequence – Render Entire Work Area) it turns green but the black bar shows up.
  • David Geary
    December 16, 2012 at 3:12 am
    looks like I didn’t search hard enough…
    https://adobe.hosted.jivesoftware.com/thread/1045471?tstart=0
  • Brendon Costello
    July 23, 2013 at 6:11 pm
    I was having a similar problem importing a high-res timelapse sequence from AE CS6 to PPro CS6 via Adobe dynamic link.
    I think I’ve fixed the problem by altering the sequence settings. Originally it was set for I-Frame only MPEG, now I set it for Microsoft AVI and it seems to have solved the problem.
  • Andrew r. Davis
    January 19, 2015 at 10:10 pm
    Brendon – I know I’m close to 2 years behind this, however I ran into this problem. Found your solution. Worked great. IFrame set to only MPEG was the reason. Don’t know if it was the source but It fixed when I changed the sequence settings to Microsoft AVI
  • Brendon Costello
    January 19, 2015 at 10:21 pm
    Nice! I’m glad I could help!
