Black background when exporting projects. Please help….
Posted by E. Lopez on December 21, 2005 at 2:51 pmGood morning,
I am a new boris red user who needs assistance with a minor problem…. When I try to export my files with an alpha background (transparent) I only get a black background. It previews with an alpha background in the preview window, but not in the final project… I believe I messed up a setting, because I was able to export fine before (The settings in the export window do say straight alpha).
Would someone please tell me how to adjust a transparent background to my projects…
Season Greetings.
E. Lopez replied 20 years, 6 months ago 4 Members · 13 Replies -
Mark
December 21, 2005 at 3:26 pmAre you sure that the editing program that you are using is set up properly to accept alpha channels ??? Where are you viewing the project ???
Cheers
Mark
E. Lopez
December 21, 2005 at 3:38 pmHello Mark,
I am viewing the project as stand alone Boris Red, I am not using my host, which is Vegas 5…But when I use the host the same thing happens, it did not happen before. I don’t know a lot about the software (just got it).
I took a picture of the screen, if you would like I can email it to you.Thanks for the reply.
E. Lopez
December 21, 2005 at 4:40 pmHello Mark,
I tried to email you the information, but got it returned… Please try sending it again or email me at: virgosmusic@yahoo.com.
Thank you
Mark
December 21, 2005 at 6:08 pmlooks like my company e-mail has blocked you also……can’t send or receive to you…..must be the yahoo mail thing.
Mark
Mark
December 21, 2005 at 7:34 pmIn case my e-mail doesn’t make it through….I suspect the alpha is there…in the second still, you are looking at RGB, so all channels…. at the bottom of the compsite window there is a button that looks like a 3 color pie…click it and select alpha…you should now see a black screen with the letters in white (the alpha)….
Also make sure that when you bring the movie back into Red that you click on the face track and that the alpha is selected.
Mark
E. Lopez
December 21, 2005 at 8:22 pmHello Mark,
Thank you so much… I tried this, but it still does not work… You know? The thing is, that the settings where fine a week ago, and now I can’t get it to work… Wow! This is frustrating… But I will keep the faith.
Appreciate all the help…
Mark
December 22, 2005 at 1:31 amHave you tried rendering out to quicktime…..give it a try, animation codec….see if that helps. I don’t have the stills in front of me, will check them again tomorrow.
Mark -
Markmc
December 22, 2005 at 11:16 amRender to uncompressed avi make sure you have checked alpha channel (premultiplied looks best in Vegas).Import avi into Vegas and put it on the timeline-right click on clip in timeline choose properties>media tab>select alpha>premultiplied.Movies with alpha channels when imported into Vegas always have the alpha channel setting set at “none” so you have to do this with any you use.
E. Lopez
December 23, 2005 at 2:00 pmThank so much,
Sorry I just wrote back; saw the messages right now. New York has been in chaos for the past couple of days (with the transit strike and all), but everything is back to normal. I will try both things, and will reply to let you know how things went.
I truly appreciate all your help.
Evelyn
