Black background when exporting projects. Please help….
E. Lopez replied 20 years, 7 months ago 4 Members · 13 Replies
E. Lopez
December 27, 2005 at 10:21 pmHello Guys,
Marc MC, the method you instructed me to do works great, thanks so much…
Marc Harvey thanks again for all you assistance… This, was a tricky one…
Enjoy the rest of the holidays and have a great New Year.
Evelyn
Rob Mclaughlin
January 7, 2006 at 12:58 amI’ve found the same problem…. when I export (to QT/mov) I’m very sure that the alpha was set to ‘straight’ in the past and it worked fine. Now the preview window looks fine, but any opacity settings seem to be ignored when exporting. (eg. a ‘fade-in’ doesn’t fade, but rather simply ‘jumps’ from 0 to 100)
I found I could fix the problem (eg. create the correct opacity changes) by setting the alpha to ‘premulti Black’ rather than ‘straight’ (still exporting to QT).
Although the exported .mov has a “black” background, it becomes a correct (transparent) alpha-channel when it’s dropped on the Premiere timeline.Hope this helps…Rob
E. Lopez
February 21, 2006 at 8:40 pmHello Robmcl…You are correct, I am having a similar problem. Mark MC gave me a solution very close to yours and it worked great.
Sorry I took so long to reply… I just saw the message.
Thanks, E. Lopez
