Activity › Forums › Adobe After Effects › Black and white?
  • Black and white?
    Posted by Natalie Deans on June 4, 2010 at 11:54 pm
    Hey,
    I was just wondering if it was possible through AE to have a shot in colour but to have it change to black and white slowly, as if stretching across the shot?
    If anyone could help it’d be great,
    cheers.
    Todd Kopriva replied 16 years, 3 months ago 3 Members · 2 Replies
  • Kevin Camp
    June 5, 2010 at 1:24 am
    you could animate a white (or black or gray) layer moving across the footage. then set the blending mode for that layer to ‘color’.
    you can get better control of the ‘expansion’ of b/w by animating mask points/shape if desired.
    animating a paint brush could also work (again, using a colorless hue and setting the blending mode to ‘color’).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Todd Kopriva
    June 6, 2010 at 8:44 pm
    I’d apply the Black & White effect to an adjustment layer and animate a mask on the adjustment layer. Or, if the transition is just a straight wipe, I’d animate the Linear Wipe effect on the adjustment layer.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
