Activity Forums Apple Final Cut Pro Legacy Black and white playback?
  • Black and white playback?
    Posted by Mario Mendez on June 11, 2007 at 5:40 pm
    I am capturing using a black magic multibridge extreme to an XRAID using fiber and a Mac pro 3ghz Quad machine. Using NTSC SD 10 BIT black magic setting and going through SDI.
    Final cut 6.0 is the version I am using.
    When I preview footage in the capture window it looks totally fine. When I capture the image in the preview window turns black and white. When I play it back it in the viewer or in a time line it playback black and white. But if I preiview it on an output monitor or use desktop preveiw it shows up in full color. The clip as all the color information in the quicktime but even if I import it seperately final will only play it back in Black and white.
    A little help please.
    MM
    Russell Lasson replied 19 years, 3 months ago 2 Members · 1 Reply
  • Russell Lasson
    June 11, 2007 at 7:46 pm
    Check to see if View-Channels is set to RGB instead of some other setting.
    -Russ
