Black and white Illustrator file color shifts when exported/rendered from After Effects?
Hi all,
Having a very frustrating problem and hoping someone has a fix:
I’m using both After Effects and Illustrator CS5. I have an Illustrator file that only has black and white colored objects in it. I import this file into After Effects, and all looks fine in my comp, until I render. The exported file turns out more greyish than pure black for some reason? No clue what could be causing this.
I tried saving my AI file as both CMYK and RGB and both produce the same result.
I also tried a workaround where I use “Color Overlay” from my layer styles in AE but this solution will not work because I’m using big blocks of white in AI file to mask out certain parts and those end up getting filled too.
I’ve tried turning “Continuously Rasterize” on and off for the layer in AE, with no luck.
FInally, I thought it might be my compression – I tried exporting at both Mpeg4 and ProRes, both with the same result.
Help!
