Activity Forums Adobe InDesign Bizzarre Color Problem when Adding Drop Shadow
  • Bizzarre Color Problem when Adding Drop Shadow
    Posted by Mary beth French on August 10, 2010 at 6:21 pm
    I’m stumped.
    I’m a graphic designer and have been working all summer doing brochures, ads, etc. I have never had this problem until this morning and to my knowledge none of the settings I have been using have changed.
    Problem: I make an image in photoshop (I’m having the problem with every extension .pdf, .psd, .jpg, etc.) When I place the image in InDesign, it is ok. When I add text to the page and apply an effect to that text (drop shadow, emboss, outer glow, etc.) the color of the picture gets darker and seems to desaturate about 60%. It does not matter where I put the text. I do NOT have the image selected when i am adding the drop shadow to the text.
    I am afraid this will affect printing as well, and seeing as how I am the graphic designer and am sending this to a company to be printed, my butt is on the line for a print ready pdf file. I would GREATLY appreciate help on this issue.
    Chris Cappilla replied 12 years, 9 months ago 4 Members · 5 Replies
  • Terry Mikkelsen
    August 17, 2010 at 4:30 pm
    What does it look like when you turn on separations preview?
    Tech-T Productions
    http://www.technical-t.com
  • Sarah Abramson
    January 8, 2012 at 11:51 pm
    I’m having the same problem. Any chance you found a solution??
    Thank you!
  • Chris Cappilla
    November 7, 2013 at 2:11 am
    yeah, Im having this problem. Any help appreciate. I’m using this light blue color for a rectangle shape and when I turn on drop shadow of type the color of the shape turn dull blue. Please any advice. Thanks!
  • Mary beth French
    November 7, 2013 at 1:51 pm
    I do remember the solution. Make sure your transparency blend space matches on everything
  • Chris Cappilla
    November 7, 2013 at 8:20 pm
    Mary, thank you so much! You saved me on this project at work. It was really annoying. Thank you again!
