Activity › Forums › Apple Final Cut Pro Legacy › Bizarre Shrinking Windows
  • Bizarre Shrinking Windows
    Posted by David Rowan on July 10, 2008 at 3:28 am
    This is bizarre.
    I have a couple of timelines (Uncompressed 4-2-2 NTSC) which I exported as “Quicktime-self contained”
    Then I open these files in a Quicktime player to check them. Some of the files then started gradually shrinking horizontally
    That is, the QT player opened up normally, but then gradually started to shrink horizontally squishing the image until the shrinking stopped at about 1/4 normal width. It would take about two minutes. If I actually hit “play” the files would shrink faster.
    Not all the files did this, and not every time. Also, trying to move the QT window around resulted in jumpy movement.
    Anyone seen this before?
    New MacPro dual-quad 10GB ram latest OS and FCS updates. Using internal drives in an array.
    David Rowan replied 18 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
