Activity Forums VEGAS Pro bitrate problems
  • bitrate problems
    Posted by Bryce Kelley on January 31, 2011 at 2:03 am
    I’m using Sony Vegas and DVD Architect.
    I used the bitrate calculator at videohelp.com to figure out how to fit multiple titles onto one 4.7GB DVD-R.
    But DVD architect shows that my disc space used is 5.1GB.
    I understand that a bitrate calculator only gives an ‘estimated’ value. But would it overshoot by this much, or is there something about this process that I’m not understanding?
    I have 4 titles, one introduction, and one menu background (video).
    All of these were calculated into the equation when I used bitrate calculator.
    The length of each video is:
    introduction: 00:00:30
    menu background: 00:00:59
    Title One: 00:29:12)
    Title Two: 00:22:53
    Title Three: 00:23:57
    Title Four: 00:27:06
    The combined duration is 01:44:37.
    I rendered the video and audio separately.
    Here are the settings I used:
    Video:
    MPEG-2
    VBR
    max: 8,000,000 bps
    average: 5,560,320 bps
    minimum: 2,000,000 bps
    Audio:
    AC3
    348 Kbps
    48,000 Hz
    24 Bit, Stereo
    When I used the bitrate calculator, I changed the ISO from 25 to 30 since in the help section, it was suggested to increase it for menus etc. Not that I’m making any complex menus, but I do plan to have the basic title selection and chapter selection options, so I increased the value just to be on the safe side.
    Any suggestions before I return to the ol’ drawing board? How should I render these files in Vegas to make them fit onto a DVD?
    I don’t want to change my audio settings and I don’t want to use DVD shrink or any other method that will decrease the quality any more than I need to. Basically, I think I just need to know how to correctly calculate my bitrates.
    But if you’ve noticed anything else I may be doing wrong, please point me in the right direction.
    B
    Bryce Kelley replied 15 years, 7 months ago 2 Members · 4 Replies
  • Bryce Kelley
    January 31, 2011 at 2:47 am
    I failed to also mention this info, just in case you need it:
    Video: 29.970 fps, 720×480 Lower field first, YUV, 6 Mbps
    Pixel Aspect Ratio: 0.909
  • Mike Kujbida
    January 31, 2011 at 3:24 am
    DVDA has a long history of incorrectly reporting file sizes.
    If you know your total file size is under the limit (and I;m sure it is), then ignore the warning and proceed as usual.
    My guess is that DVDA won’t give you any more grief.
  • Bryce Kelley
    January 31, 2011 at 5:30 am
    Thanks Mike! I’ll give it a try.
  • Bryce Kelley
    February 1, 2011 at 6:18 pm
    Well, I found that it was in fact too big to fit on the dvd.
    But then I discovered it was only because I didn’t change the kilobit size in the bitrate calculator to 1 kilobit = 1024.
    To anyone reading this post, Sony Vegas defines 1 kilobit as 1024, while some other rendering programs define it as 1000. So be sure to specify this when you’re using a bitrate calculator or you will end up with the same problem.
    Now I know! …and knowing is half the battle (as they used to say on the GI Joe PSA’s in the 80s) 🙂
