Activity Forums Apple Final Cut Pro Legacy BITC from final cut to quicktime
  • BITC from final cut to quicktime
    Posted by Nickemp on August 9, 2007 at 9:17 am
    I need to transfer a sequence to quicktime with BITC, can anyone suggest the most straight forward way of doing this without using any external decks?
    Thank you.
    Nic
    Joe Murray replied 19 years, 1 month ago 3 Members · 2 Replies
  • Rafael Amador
    August 9, 2007 at 10:14 am
    Nic,
    You want to burn the TC in top of the image, isn’t it?
    You can do it with the Filters> Video> Tc Reader or TC Generator depending if you want to burn the original TC of the clip or a new one.
    rafael
  • Joe Murray
    August 9, 2007 at 12:37 pm
    If you want it for a whole program, like for client approval, then make a new sequence and drop your existing one into it. Apply filter -set to – generate. That way you can have a continous TC for the whole prog. Watch out though it defaults to NTSC
