Activity Forums DVD Authoring bit rate calculation
  • bit rate calculation
    Posted by Lynne Margulies on December 7, 2007 at 3:47 pm
    I also posted this in the dvdsp forum.
    I’m authoring my first dvd. I know this has been addressed before, but I can’t find the exact answer I need. My program is very large, probably 3+ hours of video. I will be outputting to a dual layer dvd. In calculating the bit rate, do I calculate the video and audio separately? ie; if I have 60 minutes of video tied to audio, do I calculate 120 minutes? Or 60? I know I need to calculate separate audio (like music) in addition to the A/V.
    Also, I am editing on FCP, should I import through compressor? Or a by reference movie? I’ve done small tests as a by reference movie and it looks fine, but I am only testing in 10 minute segments.
    One more question. Can I apply a different bit rate to different segments? Like give a higher bit rate to the feature and lower on the extras?
    Thanks in advance!
    Lynne
    Alessio Gemma replied 18 years, 9 months ago 2 Members · 1 Reply
  • Alessio Gemma
    December 9, 2007 at 8:21 pm
    [marguu] “I’m authoring my first dvd. I know this has been addressed before, but I can’t find the exact answer I need. My program is very large, probably 3+ hours of video. I will be outputting to a dual layer dvd. In calculating the bit rate, do I calculate the video and audio separately? ie; if I have 60 minutes of video tied to audio, do I calculate 120 minutes? Or 60? I know I need to calculate separate audio (like music) in addition to the A/V.”
    Hi, of ourse you’ve to calculate the disk space needed to record audio and video (and graphics if there is, for example a motion menu or something like that): if you work on a MAc, download this widget to calculate bit rate/disk space.
    [marguu] “Also, I am editing on FCP, should I import through compressor? Or a by reference movie? I’ve done small tests as a by reference movie and it looks fine, but I am only testing in 10 minute segments.”
    You have to EXPORT from FCP to Compressor directly, not using QuickTime export: if your target is a DVD, you need to encode your clip in MPEG2.. so, do it exporting to Compressor directly.
    [marguu] “One more question. Can I apply a different bit rate to different segments? Like give a higher bit rate to the feature and lower on the extras?”
    Yes, you can.
    Alessio
