Activity › Forums › Adobe After Effects › birds flying under the text in the skye???
  • birds flying under the text in the skye???
    Posted by Paul Hanssen on November 17, 2011 at 12:04 am
    I have a video of some birds flying in the sky. (the cam was put on it’s back with the lens pointing at the sky and the birds flying over it)
    what i want, is to write a text in the sky and have the birds fly BELOW it, and not, as it happens now, that they fly above it. So in a way the text must be cear and transparant.
    I’m a beginner in AE, but learned basic techniques, but I can not figure out how to do it.
    I tried with Mattes, but some how i do not succeed.
    hope some one can be of some help.
    best regards,
    Paul
    John Cuevas replied 14 years, 10 months ago 4 Members · 3 Replies
  • Brian Charles
    November 17, 2011 at 12:35 am
    [Paul Hanssen] “I tried with Mattes, but some how i do not succeed.
    You’ll need to isolate the birds somehow. Either by creating an alpha matte from the color information (do a search for Shift Channels), or rotoscoping the birds which may be next to impossible depending on the number of birds, duration of footage, quality of video, (interlaced or progressive) etc.
  • Tudor “ted” jelescu
    November 17, 2011 at 8:11 am
    If you have clear sky (blue) then it should be really easy. Use a keyer- Keylight is best, a smple Color Key may work as well- to eliminate the blue in the sky and just keep the birds. Comp that on top of the un-altered clip and put the text in between.
    If you have clouds then you may need to use a Luma Key.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • John Cuevas
    November 17, 2011 at 8:38 pm
    If the camera is locked down you could try using a differnce matte. It’s really a long shot, but I’ve managed to make it work on a few occassions.
    Johnny Cuevas, Editor
