Activity Forums VEGAS Pro Binding Excalibur Scripts to Keyboard in Vegas
  • Binding Excalibur Scripts to Keyboard in Vegas
    Posted by Frankie Jones on April 20, 2014 at 4:14 am
    I use the Select Events to End Script in Excalibur a lot in Vegas, and wondered if it was possible to bind it to a keypress, to save me mousing to the toolbar to click it each time.
    Best,
    Frankie
    Edward Troxel replied 12 years, 4 months ago 3 Members · 3 Replies
  • Graham Bernard
    April 20, 2014 at 6:16 am
    [Frankie Jones]
    I use the Select Events to End Script in Excalibur a lot in Vegas, and wondered if it was possible to bind it to a keypress”
    Sure, and this in VP13, should be same for VP12:
    Go: Toolbar > Options > Customize Keyboard
    Click Trackview and enter Excalibur in the “Show commands containing” and you should get this, with all the available Excalibur commands:-
    You can see I’ve now setup the Select Events as a keyboard shortcut as Ctrl+X+E, (for ease of remembering : X=eXcalibur and E=Events) but you could set it with any keyboard combo of key presses that aren’t already in use.
    Cheers
    Grazie
  • Frankie Jones
    April 20, 2014 at 9:35 pm
    Thankyou very much, very helpful
  • Edward Troxel
    April 21, 2014 at 6:14 pm
    If you go to the “About” tab in Excalibur, you can also open the help file which explains this process as well.
    Edward Troxel
