Activity › Forums › Avid Media Composer › bin text file from Media100 to Avid Adrenaline
  • bin text file from Media100 to Avid Adrenaline
    Posted by Smiling Editor on January 12, 2006 at 7:31 pm
    We’ve recently purchased an Avid Adrenaline running on a G5/Tiger. I would like to export my bins from Media 100 (creates a txt file) and then import this into the Avid. What do I need to do to accomplish this? If this is not possible, is there a MS word format that I could type and then import into the Avid?
    Nancy
    Smiling Editor replied 20 years, 8 months ago 2 Members · 2 Replies
  • Michael Phillips
    January 13, 2006 at 12:29 pm
    Avid Log Exchange can import a standard TAB delimited Text file and convert to an ALE file format ready for import. As long as the column names are standard AVID names, the data will import into the proper fields. See:
    https://www.24p.com/ALE.htm
    Use the above reference for the column headings, the TAB file format is easy:
    StartEndTape
    01:00:00:0001:30:00:00001
    etc
    Microsoft Excel can save as TAB file as can FileMaker and any standard database program.
    In Avid Log Exchange, use File/Import/TAB
    Michael
  • Smiling Editor
    January 13, 2006 at 2:29 pm
    Thanks Michael – if you have an excel file of a log, that you could send me, that would be great! nancy@jupiterprod.com
