Activity Forums Apple Final Cut Pro Legacy Bin Shortcut
  • Posted by Eli Mavros on December 1, 2009 at 7:57 pm
    Does anyone know a short cut to create a bin within a bin, ie: make a sub-bin? I hate pressing Apple+B and naming a bin and then having to go find that bin once it gets in it’s alphabetical order and then dragging it into the bin I want to put it (which can sometime be several bins deep. There must be a shortcut, other than double clicking the bin you want it to go in and opening it up in another window and then pressing Apple+B (which is the method I usually use…but is kind of a pain sometimes, especially if that window isn’t selected and the new bin just gets placed at the root anyways. I know this is small, but it is one thing I hate on a constant basis…so hopefully there is someone smarter than me out there with a trick.
    Eli
    Roli Rivelino replied 16 years, 9 months ago 4 Members · 6 Replies
  • Roli Rivelino
    December 1, 2009 at 7:59 pm
    Right (ctrl) click inside the bin you want to create a sub-bin in and select new bin
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Eli Mavros
    December 1, 2009 at 8:24 pm
    Sometimes its the little things in life that make you happy. Some reason I never thought of that (I always assumed it made a folder in the root of the browser)! Thank you very much Roli, this should be most helpful.
    Just curious though, is there anyone out there that knows a keyboard shortcut that will create a bin inside the bin you have currently have selected? Now I’m just being fussy…but I like to use the mouse as little as I can. If not, Roli’s mouse solution will do just fine.
    Eli
    Eli Mavros
  • Jeremy Garchow
    December 1, 2009 at 8:36 pm
    If you have a numeric keypad, you hit option enter (keypad enter, not return) which will open that bin in a new tab, then hit command-b.
    Jeremy
  • Eli Mavros
    December 1, 2009 at 9:27 pm
    Ok, cool. Then I can hit control+w to close the tab once I have created my bins. I like it. Thanks.
    Best,
    Eli
    Eli Mavros
  • Kevin Monahan
    December 2, 2009 at 4:41 am
  • Roli Rivelino
    December 2, 2009 at 6:49 pm
    Get into using your mouse wheel as well, it’ll open up a world of joy for you 🙂
    System
    8Gb RAM
    Equipment
    Firestore FS-100
