Activity Forums Boris FX Particle Illusion Big Question: letters as if created by fireworks
  • Big Question: letters as if created by fireworks
    Posted by John Suzuki on May 18, 2005 at 6:05 pm
    Hello folks? I posted this in AE and I was pointed to here to ask fot help.
    I was wondering if there’s a way to make some letters as if created by fireworks.
    have any thoughts or ideas with AE or 3d app?
    I can use AE and 3d max.
    thank you all.
    Aharon Rabinowitz replied 21 years, 4 months ago 3 Members · 3 Replies
  • Alan Lorence
    May 18, 2005 at 7:22 pm
    If I understand what you’re asking for, you can do this with particleIllusion 3.0 (which is why people pointed you here). You don’t mention that you have pI3 though.
    Alan.
    wondertouch
  • John Suzuki
    May 18, 2005 at 8:40 pm
    Ahh,,,
    I was hopping to make it in AE and possiblly with 3D max.
    Thanks though,
  • Aharon Rabinowitz
    May 19, 2005 at 1:25 am
    This is definately not the best place for this sort of thing as this is the particleIllusion forum. You were probably directed here because particleIllusion is a program that could likely handle this sort of thing, and it is sheduled for release as a plug-in for After Effects in the near future (some time in june?).
    If you are not using particleIllusion (which produces nice particle effects such as fireworks) you might try using the effect in after effects called “particle system 2”.
    It’s not that simple to use, though it’s much easier to work with then “Particle Playground.” You might try asking for help in the AE forum specifically on the subject of that effect.
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    http://www.pIllusionFusion.com
