Activity Forums Apple Final Cut Pro Legacy Big Projects – Crashes – Out of Memory Error
  • Big Projects – Crashes – Out of Memory Error
    Posted by Sevan Matossian on November 10, 2009 at 8:37 pm
    2 x 3.2 Quad Core
    16GB RAM
    3 TB Internal
    12 TB GTECH gSPEEDes (Raid 5) = 9.6 TB redundant
    The project is HUGE –
    started with a 12 hour timeline (max FCP would allow me to lay down.
    3 months later I have it cut down to 5 hours and 50 tracks deep.
    This is the 10th major (over 2 hours) detailed project I have made in the past 10 years.
    All of the projects have had major issues – lost clips, vanishing clips, clips being replaced by other clips, crashing Hard Drives, exporting fiascos.. you name it..
    My current project (HD/APPLE PRO RES/ shot on HMC 150/AVCHD) is by the far the biggest I have made (5 hours complete) and it was flawless until I was unable to RENDER.
    I read through all the posts on the COW that I could find regarding this issue..
    What solved my problem was making the project file SMALLER.
    I reduced it from 400+ MBs to 190MB.
    I read it hear at the COW!
    SO, I removed all sequences from the project that were not necessary.. and walah… it is rendering perfectly.
    I let it render for about 3 hours, then I “CANCEL”, and “SAVE”. Then I start rendering again. I do this because the worst thing that can happen is 3 days of rendering and then a CRASH. YOU LOSE EVERYTHING!
    When this problem first started I could usually fix it by just quitting and restarting FCP 6.06. Eventually the problem got so bad that it just crashed after 1-2 minutes of rendering.
    THANKS COW!
    I hope this post helps somebody. Or even better, that is is never necessary 🙂
    Eric Martin replied 16 years, 6 months ago 6 Members · 10 Replies
  • 10 Replies
  • Peter Dunphy
    November 10, 2009 at 8:42 pm
    Very good post! Can I just ask – what would be a ‘safe’ way of removing sequences from a project please? I often have spare sequences that I tuck into a ‘keep safe’ bin as I’m terrified of making them offline and removing them from disk for fear of losing something!
    Recently, I’ve created new project files which only contain a minimum number of sequences and bins.
    Peter Dunphy
    2 x 2.66 GHz Quad-Core Intel Xeon, 8 GB 1066 MHz DDR3, ATI Radeon HD 4870, ATTO ExpressSAS R380, Sonnet D800 Raid 5
  • Sevan Matossian
    November 10, 2009 at 9:01 pm
    What I do –
    I duplicate the entire project file.
    Rename the new file name V1, or name V17 or whatever the newest version is.
    Then I quit FCP. Re-Open the new version and erase all unwanted sequences.
    In the past I have actually created project files that simply contain old sequences (as a back up). I am extremely paranoid about losing sequences or portions of a project.
    Maybe there is a better way …
    But this is how I have done it.
    cheers
    sevan
  • Peter Dunphy
    November 10, 2009 at 9:07 pm
    Thanks for clarifying Sevan :o)
    How do you normally erase all unwanted sequences please? Do you make it offline and leave it on the disk, or send it to trash or delete from disk?
    Peter Dunphy
  • Sevan Matossian
    November 10, 2009 at 9:21 pm
    From my understanding the “sequence” is different than “clips” (regarding how they are saved).
    I just highlight the sequence (in the browser) and hit “DELETE” on the keyboard. Of course I have the sequence saved in another project first (just in case).
    Then the sequence is GONE. But I don’t want to get rid of the clips in the sequence. I need them.
    I suspect that it is the actual construction of the SEQUENCE that is consuming so much memory/space in the project file.
    AS soon as you erase a few sequences and then hit save, you can go look at your project file in your FINDER and you will see it is significantly smaller.
  • Peter Dunphy
    November 10, 2009 at 9:22 pm
    Excellent, thanks Sevan :o)
    Peter Dunphy
  • Shane Ross
    November 10, 2009 at 10:04 pm
    Never, if you can help it, let your project files get above 200MB. I mean…wow. I try to keep mine under 100MB. HOW? Breaking the project up into multiple project files. Footage in one, sequences in another, music and effects in a third, and so on. And I duplicate projects rather than sequences.
    BUT BE WARNED…if you have one project for cuts and another for footage, you cannot match back to the footage nor the bin. Going across projects like that breaks the clip affiliation with the other project. Not a big thing to some, but it is big to others.
    a 12 hour timeline? Why?
    Shane
  • Sevan Matossian
    November 11, 2009 at 4:23 am
    Hi Shane,
    The project was 100 hours of footage shot over two days (5 cameras).
    The way I have always organized is to keep everything in ONE sequence. None of my peers seem to work this way.
    In this particular SHOW, there are more than 100 flash backs… and it has been especially useful having the entire project at my finger tips.
    QUESTION…
    Do you see any problems with the following
    I am going to
    – take the completed sequence and put it into a new project file.
    – Then render the sequence in this NEW smaller Project
    – copy the competed rendered sequence bak into my old project.
    Will the “F” match function not work on this newly rendered sequence (after I import it back into the old project file). ?
    cheers
    sevan
  • Milan Collin
    February 15, 2010 at 4:54 pm
    Hello all,
    I have the same thing over here at the moment. I was already trying to divide my project over a few sub-categories as I noticed it constantly crashes. One project size is 218MB right now and that’s the one I am working in. Now I read these post I will try to make it smaller somehow.
    I am filming for the last eight months. We have over 300hours of footage so we don’t film to much. It would be great for the editors to have excess to all the footage without opening many different projects. But it is taking a long time to open the project and if it crashes I have to restore many times.
    So I’m gonna cut the big file in two projects.
    Thanks for the post.
    Milan Collin
  • Walter Biscardi
    February 15, 2010 at 5:21 pm
    [Milan Collin] “I am filming for the last eight months. We have over 300hours of footage so we don’t film to much. It would be great for the editors to have excess to all the footage without opening many different projects. But it is taking a long time to open the project and if it crashes I have to restore many times.
    Thanks for the post.”
    Our current documentary is over 100 hours of footage and I cut it into 8 projects based on the various sections of the piece. It’s worked out quite well. Now we are in the last stages of conforming the doc and I have the compiled timeline open in one project and the Capture project opened separately. I’m able to work back and forth between the two quite well without dragging down the system.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Eric Martin
    February 17, 2010 at 5:30 am
    This may seem relatively naive, but my issue speaks to this problem and I’m sure you guys have some insight.
    What is it that when I export to an EXTERNAL drive and set my scratch discs/auto save/render/etc destination to anything and everything but my main drive, that all said main drive space is eaten away
    anyway? Seems like I’m doing everyrthing to tell FCP “Please don’t write here”, but it does what it wants
    in spite of my directives. Why is this and more importantly, where is all my drive space going and how do I recover it? When I go into the FCP docs, there is nothing current to match the consumption of said space…
