Activity Forums Adobe Premiere Pro Big Problem!!!
  • Big Problem!!!
    Posted by Trey Eckles on December 17, 2006 at 9:10 pm
    I have been using FCP studio for the past year. I have decided to use Adobe production studio b/c of the dynamic link feature.
    Here is my problem:
    I have captured all my footage using imove HD. I’ve imported all of my files into FCP and have been viewing the footage on my TV screen via firewire. Everything looks fine thru FCP. I tried to import the footage into PPro2 and it says the file type is not supported. Now I can import this file into AE with no problem quality is fine. The metadata reads that the file is DV/DVpro NTSC.
    I have noticed that in FCP the size reads 720×480. In quicktime pro the file size says 640×480 actual size. I do not know why but FCP previews the video out fine on my TV.
    I tried to export the footage out via quicktime pro (windows verison) and got the file to import in PPro2, but the size was 640×480. I even chose DV export. The quality is horrible when playing back the footage, but looks great when I stop playback (1 frame shot).
    Another issue that is taking me for a loop is the fact that I have more footage from imove HD and all I did was type in .mov and PPro 2 reads it fine with great quality.
    I know I can just import using PPro 2 but I like importing using my G5.
    Trey Eckles replied 19 years, 9 months ago 3 Members · 3 Replies
  • Steven L. gotz
    December 17, 2006 at 9:22 pm
    You are asking for trouble capturing on a Mac and editing on a PC. And you are getting what you asked for. Trouble.
    If you have a .dv suffix, or no suffix at all, you may have trouble. Change the name to .mov and see what happens. In any case, you will be rendering whenever you do anything, unless you learn to capture in the DV AVI format that a PC expects.
    I suppose you could export the file from Quicktime to a DV AVI, but there is no guarantee that there will be no quality loss.
    Steven
    https://www.stevengotz.com
  • Tim Kolb
    December 17, 2006 at 10:31 pm
    PCs do not use a resource fork attached to the file to detect what application handles it like Apple computers.
    A PC associates files with extensions…like .avi, .mov, .jpg, .psd, etc., etc.
    That’s why you type in .mov and the PC understands what to do with it.
    The frame size issue is due to improper pixel aspect recognition. The proper pixel aspect for 4:3 DV is .9, not 1.0.
    Capturing with the app you plan to edit on would no doubt be the recommendation of most on this board…particularly since you are now transferring files cross-platform and PPro will need to render QT files. DV files captured by PPro as AVIs can be edited without rendering.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Trey Eckles
    December 17, 2006 at 10:37 pm
    Thanks. I kinda figured. I just thought that it should not matter since I was capturing in DV format.
