Activity Forums Adobe After Effects Big Problem – Texture disappears in Full Render Mode
  • Big Problem – Texture disappears in Full Render Mode
    Posted by Joscha Malburg on May 16, 2007 at 12:29 pm
    Hi dudes!
    I’ve an ugly Problem. I’m working on a sweet compositing using a Grunge Background texture with Motion Tile in Length ( as we all know from Andrews Tips )
    Ive created X – Position Keyframes to slide the wall in front of the Camera. I have a nice Screenshot for this check it out
    https://home.arcor.de/bonifacius/AE_Problem.png
    all the time i worked with Third Rendersize. After a while i turned it back to Full and what happens? The Wall disappeared or to use different words it gets cut off as you can see at the Screen ( Selected is the texture and you can see the path it follows. the Wall ( with 500 length Motion tile ) gets cut off but only in Full render mode !!! I can see it while i’am switching in the timeline but when it Renders its not there anymore as you can see in the Screen.
    I Hope you have an idea for this !
    I tried to use some low result graphics but theres no sucses anyway
    greetings
    Ryan Michael replied 14 years, 9 months ago 2 Members · 2 Replies
  • Joscha Malburg
    May 16, 2007 at 7:22 pm
    i did it in draft! no sucsess 🙁
    Any other ideas?
  • Ryan Michael
    December 7, 2011 at 9:16 am
    I have found that the motion tile effect only runs in 8bit mode if your settings are at 16/32 bit the effect disappears at full render. You should notice a warning symbol beside the effect if this is the case.
