Activity Forums Apple Final Cut Pro Legacy Big Mistake while editing Canon 5 D
  • Big Mistake while editing Canon 5 D
    Posted by Andrew Gregg on December 13, 2009 at 10:19 am
    I should have consulted these forums before beginning. I think I’ve got myself in a bit of a jam here.
    I did a rough edit and synched sound between 2 Canon 5D cameras and external sound all using the files straight off of the camera in the h.264 format in final cut. I’ve got about 10 hours of footage between the 2 cameras.
    Needless to say, I’m running into issues with scrubbing speed and rendering transitions in editing.
    Is there any way to convert the original files and then somehow link the converted files back to the sequence and then change the settings of the sequence to the converted format so I don’t have to go and do all of that work again?
    I’m trying to do a batch export right now in final cut pro, but I’ve been exporting for 30 minutes now and I’m still at 0%. I haven’t even been given a estimated time yet.
    Thanks for any help or suggestions.
    Andrew Gregg
    Director
    LiveABC Taiwan
    Andrew Gregg replied 16 years, 8 months ago 6 Members · 12 Replies
  • 12 Replies
  • Rafael Amador
    December 13, 2009 at 10:58 am
    Hi Andrew,
    I think that keeping the name of the media you should be able to re-connect with the transcoed files.
    I would recommend you MPGStreamclip for the conversion. It have also batch export.
    Rafael
    http://www.nagavideo.com
  • Bjarki Gudjonsson
    December 13, 2009 at 11:52 am
    MPEG Streamclip will do the trick. I like using Compressor, and have made a great preset. I agree on keeping the names the same. It will really simplify the reconnection.
    It shouldn’t take long and the only thing you have to do afterwards is change the Sequence Settings to match the new format.
    Hope it works,
    Bjarki
  • Andrew Gregg
    December 13, 2009 at 12:48 pm
    I tried a quick sample on a couple of the clips and the audio was out of synch when reconnecting to the converted files. It seems that the timecode gets put off slightly when converting.
    What a mess. I guess I’ll just have to bear with the slow scrubbing time for the time being, then export a quicktime movie, then do the final touch ups with that.
    Andrew Gregg
    Director
    LiveABC Taiwan
  • Rafael Amador
    December 13, 2009 at 1:14 pm
    Hi Andrew,
    I’ve never worked with canon footage, but I’f I’m not wrong, it have no TC.
    Contrast this info because I’m not 100% sure.
    In these conditions re-link files properly gets much complicated.
    Cheers,
    rafael
  • Bjarki Gudjonsson
    December 13, 2009 at 3:20 pm
    Yeah, there’s no real TC on those files, they should all start on 00:00:00:00. Are the converted files themselves in sync?
    B.
  • Marc Bostrøm
    December 13, 2009 at 5:49 pm
    Are you converting to the correct framerate?
    Marc Bostrom
    -| just another PRO FCP user |-
  • Shane Ross
    December 13, 2009 at 10:42 pm
    Yeah…see, thats a big issue. Canon’s H.264 codec is 30fps straight. Any format you convert to will be 29.97…so the timecode will be different.
    Shane
  • Chris Borjis
    December 14, 2009 at 7:09 pm
    can’t you just change the render codec of the sequence
    to be prores? That should solve it without all the extra work….I’m pretty sure.
  • Andrew Gregg
    December 15, 2009 at 5:47 am
    An update for you guys.
    After a failed test, I tried again.
    I ended up using mpeg streamclip to export all of the files to XD CAM 720 30p. I then reconnected the original files to the newly formatted ones. I made a new sequence with the XD CAM 720 30p compressor settings and it worked out; most of the time.
    There were a few hiccups in there. Some of the clips were out of sych, but most were ok. All in all I’m happy to be editing in real time.
    I suppose the original test I did was with one of the problematic files.
    In any case, next time, I’ll convert first. It takes ages but it’s worth it.
    Andrew Gregg
    Director
    LiveABC Taiwan
  • Chris Borjis
    December 15, 2009 at 6:37 pm
    you didn’t try changing the compressor for the sequence?
    that alone may solve it….
