Activity Forums Adobe After Effects Big lips :()
  • Big lips :()
    Posted by Nick Cochran on May 13, 2006 at 1:24 am
    Hi, guys. The goal is to bloat the upper and bottom lip or even the entire lip region if its easier of a face. I’ve tried using the Liquid effect with Bloating applied to the areas, but can’t seem to get the effect to work using motion tracking. The only thing I can think of is to manually go in and rebloat/reconstruct :/ Any ideas?
    Jack Hilkewich replied 20 years, 4 months ago 3 Members · 3 Replies
  • Nicholas Toth
    May 15, 2006 at 1:53 pm
    if its a cartoon i’d use ccbend or bendit
  • Nick Cochran
    May 15, 2006 at 9:39 pm
    Thanks for your response! It’s actually a regular person, but the effect can be cartoony. Unfortunately, I’m not sure what ccbend or bendit is? I looked through the distort fx and did not see them there.
  • Jack Hilkewich
    May 18, 2006 at 4:05 pm
    I would try duplicating the footage then scaling up the duplicate footage to the lip size you’d want. Mask around the lips then place that on top of the original. You will have to adjust the position but it will have the same motion. You could then apply a distort effect to the duplicated layer to enhance if needed corner pin might help bring the edges into the mouth to help blend with the original better.
    Not sure but it might work.
