Activity Forums VEGAS Pro big format problem
  • big format problem
    Posted by Heidi Ho on June 1, 2011 at 6:55 pm
    Hi im new here, so i got a problem. I wanted to test the quality of the new hdpvr i just got, so i put together some clips in sony vegas pro 10. But when i rendered in .mov file the quality was way lover than 720p, that it was before rendering. And when i rendered in .avi it got great quality, but it was lagging extremely much. Plz help
    Heidi Ho replied 15 years, 3 months ago 2 Members · 4 Replies
  • John Rofrano
    June 1, 2011 at 7:43 pm
    You don’t want to render to QuickTime as it won’t give you the best quality. Let’s make sure that you have everything set up correctly:
    Your record settings on the HDPVR should be AVCHD format.
    Your project settings in Vegas Pro should be: HDV 720-30p (1280×720, 29.970 fps)
    Your render settings should be: Sony AVC with the Internet 16:9 HD 30p template.
    That should make your renders look as good as the original.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Heidi Ho
    June 1, 2011 at 8:14 pm
    thx gonna try that :). btw do i have to film again to record in AVCHD?
  • John Rofrano
    June 2, 2011 at 3:36 am
    [jan stephan bentze] “btw do i have to film again to record in AVCHD?”
    Yes, so maybe try that the next time. AVCHD from the HD-PVR edits better in Vegas.
    ~jr
  • Heidi Ho
    June 2, 2011 at 9:58 am
    THX now it works 😀
