Activity Forums Apple Final Cut Pro Legacy big endian – codec
  • big endian – codec
    Posted by Marc Nibor on February 26, 2008 at 1:53 am
    hi, i hope this is not a dupe post…. my first attempt was not accepted since i hadn’t switched my old username yet.
    again one of those codec questions ; ) I hope this is the right place to ask.
    i received a 2 gig quicktime movie. on the disc is written – big endian codec –
    afaik the material was recorded with a betacam and is from a avid workstation.
    i do NOT have FCP and do NOT own a MAC ; )
    is there any way to convert this material on a PC to?
    or open/play it on a PC?
    i thought it would be a good idea to ask here before installing one of those dreaded codec packs without knowing exactly what i do.
    Marc Nibor replied 18 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Gissing
    February 26, 2008 at 5:37 am
    Big Endian is the audio codec (in this case PCM )and is not the video codec. Do you have quicktime player on your PC? If so when you open the file what happens?
    If it says it need to download a codec and that fails then you should go back to the person who made the disk and ask them. I can’t possibly guess from the info supplied.
  • Marc Nibor
    February 26, 2008 at 2:09 pm
    Thanks a lot for looking into it.
    ok, here is all the additional info that I could get.
    the disc is labeled: Codec – Integer – Big Endian
    Quicktime DID show the “have to get additional software……” and I was letting it do it’s thing.
    the player opens, and the window switches to the correct size. But all I see is white – the player even shows the correct time of the clip and i can scrub through it. but nothing – only white all over.
    this is the info that i get when i load it into a converter:
    Vid Frame Size: 1024×576
    FPS: 25
    Video Codec: Uncompressed 10-Bit 4:2:2
    Interlacing: Lower First
    Aspect Ration 16:9 Pixel 1:1
    Audio 48.000kHz 16 Bit Audio Codec 16-bit Big Endian
    if I try to convert it I get the same result. white frames – nothing else.
    as i said, to my knowledge this clip was made on a mac workstation running avid and it was sent to me from a professional cutting facility.
    the big prob is that I cannot reach anoyone there until beginning of next week but I need to work on the footage
    any ideas are welcome. even if it’s a hassle : )
  • Rafael Amador
    February 26, 2008 at 4:30 pm
    You can not open an Apple Uncompress movie in a PC. That codec is not supported by QT in that platform.
    The Big or little Endian is not here the issue.
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
  • Marc Nibor
    February 26, 2008 at 5:34 pm
    ok, so I already made an appointment tomorrow with a Mac guy
    and he will open the file for me….
    The only prob is… He is not really experienced in this field and I am a total beginner when it comes to macs.
    sorry for this 1st grade question, but can someone please give me a brief guideline on what i need to do?
    I need this uncompressed apple movie in a format that i can open on a pc. possibly with the least amount of quality loss.
    thank you
  • Arnie Schlissel
    February 26, 2008 at 11:09 pm
    [Marc Nibor] “afaik the material was recorded with a betacam and is from a avid workstation.”
    I don’t mean to sound crass, but that’s not really an FCP issue.
    [Marc Nibor] “i do NOT have FCP and do NOT own a MAC ; )
    or open/play it on a PC? “
    Again, not an FCP issue.
    You should contact the facility that made the file & tell them specifically what format you need it in.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Rafael Amador
    February 27, 2008 at 2:06 am
    Download and install the Blackmagic codecs (free), and export the file as Blackmagic 10b Uncompressed. You won’t loose quality. Then you just need to install the same codecs in the PC to get the files opened.
  • Marc Nibor
    February 27, 2008 at 2:33 pm
    Thank you very much for this very helpful answer !
    Great : )
