Activity › Forums › Adobe After Effects › BIG BIG Image or 3D ??? please help .. Urgent …
  • BIG BIG Image or 3D ??? please help .. Urgent …
    Posted by Aroonzfx on August 8, 2006 at 5:58 pm
    hi all @ cow
    i wanted to create a montage in which the camera zooms in to several pictures and finally into the title text…i will explain it..
    its already discussed here itself in cow…
    is it better that i build the image wall in photoshop and then save it as jpg or should i stick on to a 3d program ?
    the problem is that i want to pan into all the images in the image wall and all those images should be clear ..
    what should be done ?
    can u guys plz lead me
    thanx
    aroonzfx
    Fabiano Peres replied 20 years, 1 month ago 2 Members · 1 Reply
  • Fabiano Peres
    August 9, 2006 at 11:30 am
    Well, I would create different JPEG files (one for each image) and make them a good resolution, I never zoom in an image over 100% its size, so according to you animation, decide what’ the best resolution. Then in After Effect I’d make them 3D and create a videowall with the images (if you have 3D assistant from https://www.digitalanarchy.com/3Dassist/3Dassist_main.html you can do it with a few clicks)then, just animate the camera the over them.
    I hope it helps.
