Activity Forums Audio Bias Soundsoap
  • Bias Soundsoap
    Posted by Nicholas Bierzonski on April 25, 2006 at 1:29 pm
    I have used Soundsoap many times in the past as a plug in in FCP. I always manually dial out the noise because if I use the learn noise function of Soapsoap it works but…when I play play the clip there is a delay of about 1 second before soundsoap kicks in. You can hear the room tone in all of it’s glory for about a second then Soundsoap kicks in and the noise disappears. Why does this happen? Does this happen to anyone else?
    I tried putting nodes on the audio for the first second of the clip that dropped the audio out. Soundsoap still waits a second after the first part of the clip with audio to kick in. Any ideas or suggestions?
    -Nicholas Bierzonski
    Editor/DVD Author/Java Boy
    http://www.finalfocusvideo.com
    Nicholas Bierzonski replied 20 years, 5 months ago 1 Member · 1 Reply
  • Nicholas Bierzonski
    April 25, 2006 at 1:41 pm
    I forgot to mention that unlike when I use Soundsoap in Peak if I hit the learn noise button…the default parameters do not change. So also can’t tweak them and make adjustments.
