Activity Forums Boris FX Particle Illusion BG Image disappearance…
  • BG Image disappearance…
    Posted by Ra-ey Saleh on February 8, 2008 at 12:34 am
    Guys,
    Can’t work out what I’m doing wrong.
    Essentially, all I want to do is import a BG image with alpha (which I see clearly on my stage) then export it and still see it.
    Tried every possible way, but when I import the AVI into my Avid, the BG image with Alpha is no longer there. A BG image without an alpha works fine.
    Ra-ey Saleh replied 18 years, 7 months ago 2 Members · 2 Replies
  • Alan Lorence
    February 8, 2008 at 1:09 am
    If you’re saving alpha in the output, the alpha channel is created for the particles only — the alpha of any bg footage is discarded.
    So you’ll need to add that bg footage back at the compositing stage.
    Alan.
    http://www.wondertouch.com
  • Ra-ey Saleh
    February 8, 2008 at 1:14 am
    Thanks Alan, saved me going insane.
