Activity › Forums › Apple Final Cut Pro Legacy › beware quicktime pro users!!! Do not upgrade to 10.3.9
Doug Olin replied 21 years, 4 months ago 11 Members · 15 Replies
Mike
June 1, 2005 at 6:59 pmArnie,
I only upgraded one of 27 macs to QT7 and then did with no more. Its all of the machines that I didn’t upgrade to QT 7 but DID upgrade to 10.3.9 that I am SOL with. Apple wants me to pay for the QT pro upgrades (27 times $27.99) because they broke my QT without warning me and wont make it right. I should throw in some lube so they can gracefully remove their heads from their a$$e$.
Arnie Schlissel
June 1, 2005 at 7:03 pm[Mike] ” Its all of the machines that I didn’t upgrade to QT 7 but DID upgrade to 10.3.9 that I am SOL with.”
All I can say is that my experience has been different. I upgraded to 10.3.9 when it came out, but have stayed with QT 6.5.2, & all is well. But, that’s my setup. Clearly yours are different.
Arnie
https://www.arniepix.com -
James Hargreaves
June 1, 2005 at 10:45 pmUpgrading to FCP 5 (I upgraded to FCP Studio) will “Pro” your QT 7 in the process.
Shane Ross
June 1, 2005 at 11:15 pmMike,
I will echo what other people are saying and you are not really hearing…
You do not need QT 7 if you are running 10.3.9. QT 6.5 works just fine.
I hate to be one of the people going “nyah nyah nyah…it works for me…nya nyah nyah” but it DOES work for me. And it works for several OTHER people as well. This would suggest that something else is up…something else is causing your woes. Sure, it might have happened when you did the upgrade, but the upgrade might have caused the problems in other ways.
I don’t know what else to say that will convince you.
Doug Olin
June 1, 2005 at 11:41 pmWe have 2 FCP systems. The system I use every day, as the only user, works fine with 10.3.9. The other system is the one with the problems in opening a single FCP project. This one project on the other system is the reason I tried downgrading to 10.3.8.
BTW I tried opening the problem project on the other system today and it wouldn’t open. I’ve trashed preferences, reinstalled FCP and the OS and thrown away all render files but it doesn’t like to open after saving a new version. Any other ideas on causes for this? The project file is about 22 MB and contains many nests and unused footage files. Could the file bloat be causing the opening problems?
Doug Olin
Pensacola Christian CollegeG5 DP 2.0, 2 GB RAM, FCP HD, IO, OS 10.3.9, Medea RT3X 1200 GB
