Activity › Forums › Creative Community Conversations › beware of 7tox
beware of 7tox
Posted by Carsten Orlt on January 31, 2012 at 10:03 pmBe very careful if you are considering the 7tox translator.
Very exited that I was i bought it thinking $10 can’t be better spent
BUT
media has to be online in order for it to work…..This of course makes it basically unusable but for the last project you worked on (if that)
Hope I can safe a few people some money!
Thomas Frank replied 14 years, 7 months ago 11 Members · 14 Replies -
John Godwin
January 31, 2012 at 10:23 pmWorks fine here. Any current projects are online. Any completed projects are archived to cheap backup hard drives (2 copies) and would have to be reloaded to my raids in any case if I needed to work on them.
Best,
John -
Shane Ross
January 31, 2012 at 11:06 pmI’m unclear what your needs are.
[Carsten Orlt] “This of course makes it basically unusable but for the last project you worked on (if that)”
Why isn’t it good for the current project you are working on…in FCP 7?
And why would you convert a project from 7 to X if there is no media?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Carsten Orlt
January 31, 2012 at 11:17 pmBecause I have projects from the last 10 years which contain footage I still want to use.
Even if the media is backed up it would take me a long time to restore (tens of hours of footage on LTO per project, and there are many).
I spent weeks and weeks describing all the shots and it would be nice if I could translate that to X, but I think the only real workable solution is CatDV.I understand that 7toX will work for many people, but I wanted to make users aware of this specific limitation.
Of course it was my mistake to not read the fine print 🙂
Carsten
Shane Ross
January 31, 2012 at 11:19 pmYeah…I think that for what you want to do, this isn’t the app to use…
Shane
Little Frog Post
John-michael Seng-wheeler
January 31, 2012 at 11:59 pmSince the media must be online, you still need to have a working copy of FCP7 around as long as you want to get to your old projects….that could really stink in a few years.
Michael Gissing
February 1, 2012 at 12:02 amA second internal boot drive with legacy FCS3 and Snow Leopard @32 bit is the best way to achieve that, I am sure Lion will break FCS3 eventually
David Roth weiss
February 1, 2012 at 12:07 am[Michael Gissing] “A second internal boot drive with legacy FCS3 and Snow Leopard @32 bit is the best way to achieve that, I am sure Lion will break FCS3 eventually”
Or, you could follow the directions in this cool tutorial to setup a multi-partition boot drive: https://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Michael Gissing
February 1, 2012 at 12:27 amActually David I will have to do that if I want to experiment with FCPX as my MacPro is full with RAID’d internals, unless I use the optical drive bay.
Jeremy Garchow
February 1, 2012 at 1:35 amYou could also run a clone off of an external FireWire drive just for this purpose.
Even new macs which don’t allow clean snow installs can still boot snow OS.
Kevin Patrick
February 1, 2012 at 11:45 amI was under the impression that new Macs, as in Mac purchased since Lion was released have firmware changes that won’t allow you to install Snow Leopard. I recall reading some Mac Pro threads on this topic a while ago and that’s what I thought the conclusion was.
