Activity › Forums › Maxon Cinema 4D › Beveling the booleaned text
  • Beveling the booleaned text
    Posted by Cem Gul on September 28, 2013 at 12:23 pm
    I need proper beveled edges for the text subtracted from a sphere but I got jaggy edges when I make the object editable to add bevel.
    Spline mask method works well for extruded objects but sphere is what I need.
    Any idea will be appreciated. Thanks
    Cem
    Cem Gul replied 13 years ago 3 Members · 8 Replies
  • 8 Replies
  • Adam Trachtenberg
    September 28, 2013 at 3:35 pm
    Beveling and booleans don’t get along in C4D, unfortunately. Maybe you could try a displacement map instead?
  • Cem Gul
    September 28, 2013 at 3:38 pm
  • Brian Jones
    September 28, 2013 at 5:31 pm
    RBoole – https://www.plugins4cinema4d.com/rboole.html – can do clean booles that don’t show any artifacting from cut polys
    It’s not free (but not expensive) and it does have limits (sometimes objects have to be editable etc) – your rendered scene, which is obviously a lot more complex than the Boole-Sphere-MoText you have showed us might need some work but it should render well. Can you post the final scene (just the single S part in the lower left image don’t need texture or environment) I could see if RBoole will handle it cleanly
  • Cem Gul
    September 30, 2013 at 10:27 am
  • Brian Jones
    September 30, 2013 at 9:28 pm
    this is the difference between Boole and RBoole
    with texture and lights and a Sky for environment specially made to enhance the boole’s limitations. There seems to be something wrong with the file as I have trouble getting RBoole to work without making the MoText editable (which is where the pics come from) but if I recreate the scene in a new document a MoText works fine – though I had to use an alternate S – what is the font you are using?
  • Cem Gul
    September 30, 2013 at 11:06 pm
    Helvetica Rounded Bold Oblique
  • Brian Jones
    October 1, 2013 at 3:09 am
    not one I have, but either way it’s working when I create the object from scratch with whatever font I use in the MoText
  • Cem Gul
    October 1, 2013 at 11:24 am
    Thank you Brian I’ll give Rboole a try.
    Cheers
