Activity Forums Zaxwerks Bevel in Invigorator
  • Bevel in Invigorator
    Posted by Simka Cvetkovic on February 27, 2008 at 6:45 pm
    Hello everyone
    my question is…is it possible (I guess it is) to make some kind of bevel look in Invigorator but on the fron side of your object.For example..I have an flat object (a star for example).With Invigorator I’ve got a 3D object,but I’ve noticed I can do all kind of different styles (add them and remove them) but only on the side of my star…I didnt manage to do it one the front side of the star.I hope I didnt confuse you with my question.
    Thank you in advance!
    Simka Cvetkovic replied 18 years, 7 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    February 28, 2008 at 1:30 am
    Hi Simka,
    Bevels can be applied to inner and outer edges but cannot be applied to front and rear faces in Invigorator. Your best bets are to make the front and rear face very small (or even turn off visibility and manipulate the bevel size and offset. If that doesn’t work, you can use other 3D modelers and import the object into Invigorator for animation.
    Does this help?
    Jon
  • Simka Cvetkovic
    February 28, 2008 at 1:59 am
    Thank you very much!I tought there is a way to add a Bevel to the front face of the object.I’ll try something else and If I stuck again I’ll come back to ask for help again. 🙂
    Thank you one more time!
