Activity Forums Adobe Premiere Pro Better to convert VOD to MOV or AVI for Premiere CS2?
  • Better to convert VOD to MOV or AVI for Premiere CS2?
    Posted by Gavino on June 18, 2007 at 9:02 am
    Greetings,
    I am just wondering if it is worthwhile converting the VOD footage I obtain from my DVD camcorder to a lossless compression format such as mov or avi before editing it in Adobe Premiere Pro CS2.
    Thanks.
    Blast1 replied 19 years, 2 months ago 3 Members · 4 Replies
  • Alex Jusay
    June 18, 2007 at 11:16 am
    Gavino,
    1. VOD or VOB?
    2. AVI or MOV can be lossless or lossy depending on the codec. DV or MOV AVI is a lossy codec. Uncompressed AVI is technically a lossless codec.
    3. Nop, its not worthwhile because the source is compressed anyway. I would go for DV codec, AVI or MOV.
    Hope that helps…
    Jhalex
  • Blast1
    June 18, 2007 at 7:49 pm
    Change the .vob file extension to .mpg then import into Ppro2
  • Gavino
    June 19, 2007 at 4:12 am
    Thanks for your swift response.
    I have come to understand that my purchase of a DVD camcorder was a bad one considering my desire to edit footage through Premiere Pro CS2. I was hoping that there was a way that I could uncompress the VOB footage I obtain from my camera, then edit it before compressing it into its final form. As it stands, my final output from PRemiere Pro is a compressed version (MPEG-2) of already compressed footage (MPEG-2). That doesn’t sound healthy! Any advice?
  • Blast1
    June 19, 2007 at 8:09 am
    If you are going to have the cam for a while you might want to look into videoredo.com it uses smart rendering so impact is minimal to the Mpeg video
