Activity › Forums › Adobe After Effects › Better Res
  • Better Res
    Posted by Chuck Obernesser on April 27, 2008 at 1:01 am
    Hello to all…
    I made a 1:30 comp and it contains newspaper ads that were created in adobe illustrator. I have the camera passing by the ads at a slow to mod rate of speed. The exported it as an ani. at 29.97 as a D1 and square pix. But it makes the text and some pic’s look jumpy. Is there any way to change that? I found in advanced options in the comp settings that i can change the shutter speed. Would that help? Thanks for any and all help!
    Chuck
    Obernesser Productions
    http://www.obernesserproductions.com
    Darby Edelen replied 18 years, 5 months ago 2 Members · 1 Reply
  • Darby Edelen
    April 27, 2008 at 4:13 am
    The shutter angle changes the amount of motion blur in the comp (I think you meant angle when you said speed?).
    If the motion is not smooth, you could try adding more motion blur (or start by enabling motion blur if you haven’t yet) and that may help. Or if the finished render is destined for broadcast or an interlaced display you could render with fields for smoother motion (although it will look odd on your computer).
    What is your plan for this footage?
    Also, your question wasn’t about this, but If the imported assets are all vector graphics you can enable the ‘continuously rasterize’ switch on the layers (it looks like a sun). This will keep all vector graphics sharp at any scale/distance to the camera. This doesn’t work with bitmap elements.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
