Activity › Forums › Adobe After Effects › better mask manipulation plug-in perhaps?
  • better mask manipulation plug-in perhaps?
    Posted by Andrei-cristian Murgescu on September 29, 2006 at 10:30 am
    Hi folks!
    I’m working on bout 18 shots that require heavy masking manipulation. I was wondering if there is a plug-in of some sort that would ease a bit (or in fact speed up) maniupalting control ponits and handles, etc. etc.
    Best,
    CB
    Justin Productions replied 20 years ago 3 Members · 3 Replies
  • Justin Productions
    September 29, 2006 at 2:59 pm
    If you are rotoscoping (with masks), you could use a proxy for the layer that you are working on. Or even turning the Mask mode to “None”.
    Try Open GL, turn down the comp quality to “Half”, use keyboards shortcuts if that can help. That always speed things up.
    Just a few recommandations.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Mylenium
    September 29, 2006 at 5:41 pm
    Get Silhouette Roto. It works both as a standalone and plugin to AE and is much better in terms of interactive feedback than AE itself. You can’t do much in AE to speed things up – even changing the resolution as Justin suggested doesn’t really make things slicker plus it adds the risk of misaligned masks because you are not seeing the full number of pixels.
    Mylenium
    [Pour Myl
    September 30, 2006 at 2:00 am
    Yeah you’re absolutely right. Depending on the precision he wants.
    My bad.
    Justin Productions
