Activity Forums Apple Final Cut Pro Legacy Beta is not 720 pixels wide
  • Beta is not 720 pixels wide
    Posted by Keith Heard on November 21, 2008 at 6:38 pm
    I need to edit a program using SD footage shot DVCam 16×9 & Beta SP 16×9. The final output will have the 16×9 footage “letterboxed” in 4×3. I have decided to capture all of the footage using DV/NTSC since this is 720×480. Using a 720×486 codec such as Apple Pro Res gives me 6 extra lines on the DVCAM footage which reveals all the tech info in the interval bar at the top. I’m trying to avoid cropping and/or resizing since this is a huge project with a lot of footage.
    My problem now is: When I capture the Beta SP footage using any Codec, even uncompressed, there are two thin bars on the left and right side of the video. I am seeing this in my “viewer” and my “canvas”. So… these lines are way outside of the “safe action zone”, however, since I am going to have a web version the lines will be noticeable when I cut between my DVCam & Beta SP footage.
    Has anyone ever had problems with Beta SP footage not filling the entire width? It’s almost like the image is 714 pixels across instead of 720. However, I do believe it is 720 pixels wide because the “blue box” which outlines the image when the clip is selected in the sequence is spanning the whole width. So it looks like the extra lines of the image are black.
    I did record from another Beta SP tape and had the same problem. I’ve tried different decks. Even saw the problem on an entirely different FCP editing system.
    I just wish that when they say it’s 720, then it is 720. I know 720, I’ve seen 720, and this is not 720. Black, or anything other than the image, does not count!!!
    Sorry, but I do feel better now.
    Thanks in advance….
    Keith
    Keith Heard replied 17 years, 7 months ago 10 Members · 14 Replies
  • 14 Replies
  • Walter Biscardi
    November 21, 2008 at 7:34 pm
    [Keith Heard] “Has anyone ever had problems with Beta SP footage not filling the entire width?”
    Yep, all the time. I can’t remember the last time we saw BetaSP footage that actually did fill the entire frame horizontally.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • David Roth weiss
    November 21, 2008 at 7:59 pm
    Keith,
    Several things coem to mind from reading your post…
    1) You’re monitoring full frame in FCP on your computer display and you’re seeing things that would be outside of action safe on a TV or broadcast video monitor. Well, sure… video was invented for broadcast transmission, while Web delivery is a very recent development. NLEs are based upon broadcast standards, so you have to adjust for Web delivery, rather than the other way around.
    2) The workflow you’ve decided to adopt is not necessarily the best workflow. You’re probably far better off capturing the video as it was intended, i.e. 16×9, then either editing as is or in a 4×3 timeline. This will allow you to re-size the video instead of being stuck with what you get by capturing letterboxed, and you will be able to address your concerns about the what you see and don’t see when you re-size. You can re-size one clip and copy that, or edit 16×9 and re-size when you’re done.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Keith Heard
    November 21, 2008 at 9:49 pm
    “I can’t remember the last time we saw BetaSP footage that actually did fill the entire frame horizontally.”
    That’s what I thought. Thanks.
  • Tom Matthies
    November 21, 2008 at 9:55 pm
    The lines are called Blanking and will be seen on almost any analog camera recording. They aren’t a defect-they are just part of the signal from that older analog format.
    Tom
  • David Roth weiss
    November 21, 2008 at 9:59 pm
    [Tom Matthies] “They aren’t a defect-they are just part of the signal from that older analog format.”
    And, it would have been outside of action safe and thus hidden from view…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Tom Matthies
    November 21, 2008 at 11:17 pm
    Except when played on a computer screen. The blanking is then clearly visible at the edges of the window.
    Tom
  • Keith Heard
    November 21, 2008 at 11:24 pm
    “NLEs are based upon broadcast standards, so you have to adjust for Web delivery, rather than the other way around.”
    Thanks David, but I wouldn’t have to resize anything if Beta SP was indeed 720. 720 should be 720, just as it is with DVCam. Pixels matter! After all, we delineate between 486 and 480.
    I haven’t given up on this yet. There has got to be a better explanation.
    The difference between footage is:
    Beta SP 16×9 (Betacam) DVCam 16×9 (Sony DSR 450)
    Analog Digital
    720×486 720×480
    Capture Presets Tried: Capture Presets Tried:
    Apple Pro Res 720×486 16×9 DV 720×480 16×9
    10bit Uncompressed 720×486 16×9
    DV 720×480 16×9 (worked best w/ my DV footage, made letterboxes the same except for above mentioned problem)
    I also tried the above presets without 16×9 (anamorphic) selected
    I’m using an AJA Kona LH.
    STUDPID QUESTION: Is there a difference in pixel size between analog beta and DV?
    Thanks!!!!!!!
    Keith
  • Peter Wiggins
    November 22, 2008 at 1:32 am
    Beta SP has a narrower picture than a 4:3 digital format hence the black lines.
    It has always been like that. Not to mention the dropouts 🙂
    Peter
  • Mark Suszko
    November 22, 2008 at 5:50 am
    Maybe, you don’t need to sweat the beta’s framing; you have a separate cropping option or two in your web compression settings and within the extra settings in compressor and quicktime pro. So I’d worry about treating it at the end stage, I think. Which is perhaps good news? Why not mess with those and render out ten seconds worth to test it?
  • Scott Thomas
    November 22, 2008 at 9:09 am
    I have to agree; Beta is not 720 pixels across. Nor is it 512 or 704 or any other combination of pixels. It is an analog format and predates ITU-R 601 standard sampling. You could sample it at 1280 pixels across, and the blanking would be right there in the same place.
    The whole issue of number of scan-lines is also interesting. ITU-R 601 defines 720 samples of luminance on each scan line. There are 486 active lines. DV or DV-Cam or DVC-Pro are formats based on Discrete Cosign Transform (DCT) codecs. DCT codecs need images that are evenly divided by 16 and 486 does not evenly divide by 16. To accommodate this need, six scanlines were lopped off the top and bottom… Kind of like how analog blanking encroaches upon the dear 720 horizontal samples.
    You lost a few samples on the left and right. I lost six scanlines. Lets call it even.
