best workflow for multicam editing with a large number of separate clips and dual system audio
Hello!
Coming from FCP7, I’m having a hard time finding a good workflow for multicam editing with lots of different clips from a single event. After editing the synced clips, I’ll export sections of the whole project into 10 short tutorial videos.
My project is a music lesson with two camera angles and two external audio sources. I started and stopped the camera and recorder a lot, so the result is around 20-30 small clips, all synced up in a multicam clip.
Now, I have a few goals for the end result:
1. mark all the sections of video/audio I’d like to split out into separate videos
I do this in the project timeline with a single multicam clip. Should I be doing this some other way, perhaps using ranges?
2 Some sections of the clip will fade back and forth between angles
This works OK just using the standard angle viewer cut technique.
2. Other sections must be split screen between the two angles
I’m not sure how to do this without duplicating the whole multicam clip. If this is the only way, should I duplicate it after doing all the audio editing work mentioned below?
3. Audio should be stereo panned for some sections
Normally I do this in the multicam clip angle editor, but ideally I could work with the audio and video of each section of the larger multicam clip clip separately. Is this possible?
In general I feel I’m missing something basic about FCP X that might make this easier, where I can work with each section separately. Thanks for any help!
Joshua
