Best Workflow for Alexa 2K (ProRes 444) with Adobe Premier Pro 2015.3
I’m cutting a feature using Alexa ProRes 444 footage and Premier. What is the best workflow for this arrangement?
I have a mid-2012 MacBook Pro 2.6 with 8 GB Ram running Yosemite.
Is it reasonable to cut natively or should I use a proxy workflow. We will be syncing and merging clips to cut with so they would have to be matched back laster if we use the proxy path.
I have a faster imac that we could use but it’s running Sierra but I’ve been advised to stick with Yosemite for now.
Rachel
