Activity › Forums › Apple Final Cut Pro Legacy › best way to save under expose material?
Posted by Ipazia on April 1, 2006 at 10:29 ambest way to save under expose material?
my first time shooting people with dark skin… I end up with under expose dark material
anybody can suggest me the best way to try to save it
I tried with a couple of filter but I guess i am not able
grazie barbaraMatthew Brunn replied 20 years, 5 months ago 3 Members · 3 Replies -
Tom Meegan
April 1, 2006 at 1:20 pmTry a Effect > Video Filters > Image Control > Levels if you are on FCP. The controls are a bit odd to get used to at first, but experiment and you will get it. There a bunch of other filters to try as well, but this one attacks your problem directly.
Bottom line is that if the black in your image no detail at all, there will be no information a filter to work with.
When you attempt these corrections, watch your work on the output monitor it is destined for. An NTSC monitor will look very different than a computer monitor. Make your corrections for the format your audience will see.
Tom
Tom Meegan
Tom
Matthew Brunn
April 1, 2006 at 2:47 pmYou may also try duplicating the clip to the layer above and making the one on top an “additive” mode. Then adjust opacity to re-expose the the clip.
Hope this helps-
Matthew
Quad 2.5 G5
OSX 10.4.X
Ram 4GB
FCP 4.5/AE 6.5/DVDSP3
