Activity › Forums › Adobe After Effects › Best way to render an animation in AE for use if Final Cut Pro with the 422 codec???
Posted by Mel Kahn on February 18, 2011 at 7:36 amHi, Anyone know the best way to render an animation already done in AE so that one can move it over to Final Cut Pro (say version’s 3 and up) to be able to use the Pro Res 422 codec for the best HD results???
Mel Kahn replied 15 years, 6 months ago 3 Members · 4 Replies -
Joey Foreman
February 18, 2011 at 1:55 pmSure, just render it to ProRes HQ.
[Mel Kahn] “…so that one can move it over to Final Cut Pro (say version’s 3 and up) “
Final Cut is currently on version 7, which is part of Studio 3. ProRes can only be used with versions 6 & 7, as far as I know.
Joey Foreman
Editor/Compositor/VFX Artist -
Darby Edelen
February 19, 2011 at 2:38 am[Dave LaRonde] ” To add to Joey’s information, only Macs with Final Cut 6 or 7 install on them have access for ProRes 422. No other machine has the codec. Thanks a bunch, Apple.”
You can download the read-only version of the codec for Windows (and possibly OS X, it’s been a while) from Apple’s website.
Also, if you know anyone with the codec component they can send it to you. These go in your Library/QuickTime folder.
Darby Edelen
Mel Kahn
February 20, 2011 at 1:27 amThanks for the info!
If this was originally done 720 x 480, would you leave it that size in AE, and then change it to 1920 x 1080 in FCP, or change it to 1920 x 1080 in AE first?
MK -
Mel Kahn
February 20, 2011 at 1:31 amHi, and thanks for the info!
If the animation was originally made 720 x 480, (and it has to be 1920 x 1080). would you change the size in AE or leave it and change it in FCP?
Don’t know which version (FCP) end up using, but if you wanted an uncompressed file out of AE, what would you use?
MK
