Activity Forums Apple Final Cut Pro Legacy Best way to remove hum from audio clip in FCP
  • Best way to remove hum from audio clip in FCP
    Posted by Tsylla on November 4, 2006 at 10:04 pm
    Hello, I have an audio clip in Final Cut Pro and wish to remove the hum. I’m not that familiar with the audio filters in FCP. Any suggestions on the best way to do this? I can send a sample of the clip if that helps.
    Thanks.
    Tom Sylla
    Noam Osband replied 11 years, 4 months ago 9 Members · 10 Replies
  • 10 Replies
  • Bouncing Account needs new email address
    November 4, 2006 at 11:12 pm
    Depends on the kind of HUM.
    But start with (are you ready?) the “Hum Remover” filter.
    Try removing the various “harmonics” and listen to how it sounds after each change.
  • 13 Create COW Profile Image
    13
    November 4, 2006 at 11:49 pm
    Use Soundtrack Pro
  • Tsylla
    November 5, 2006 at 1:28 am
    Thanks. I’m assuming that checking the box next to a harmonic removes it….?
  • Debe
    November 5, 2006 at 4:54 am
    You’ll have to play around with it, tsylla.
    It’s unlikely that your specific hum will be removed with the default settings. It depends on the source of the hum, really. It’ll take some futzing.
    Otherwise, look into Reduce Noise in SoundTrack Pro’s manual.
    debe
  • Gunleik Groven
    November 5, 2006 at 7:52 am
    Depends much on the characteristics, but soundsoap (a commersial plug) and some eq’ing could be a route if the other suggestions don’t pan out.
    Gunleik
  • Paul Nevison
    November 6, 2006 at 11:14 am
    soundtrack pro is your ticket. I had to remove a terrible earthing hum on an interview last week. the reduce noise feature in Soundtrack was just incredible….highlight the hum in the soundtrack pro timeline, go to process and select set noise print, then reduce noise….heaps of control to elimintate the hum.
    the only downside is that you may experience some audio artifacts…these can mostly be fixed with EQ.
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 5.7.2
    PAL Land
  • Tsylla
    November 14, 2006 at 5:33 pm
    Thank you thank you! It works like magic.
  • Tom Laughlin
    August 10, 2010 at 9:08 pm
    Hmmm — maybe cancel my last request for help in removing hum — my real challenge in Soundtrack Pro seemed to be highlighting/selecting the portion to be dealt with — I may have managed to do it by adding a marker at that point, placing the timeline cursor over it and then using the ‘Set Noise Print’ and ‘Reduce Noise’ options. The machine is processing things (slowly — how long does this take on a short clip?) now so I’ll see what happens — if anyone wants to confirm my approach or otherwise add input, great — thanks—
    Tom in Wisconsin
  • Ailín Ó broin
    April 12, 2012 at 9:57 pm
    Great answer, thanks! I have spent many a day trying to reduce noise with frustrating results. This works so well!
  • Noam Osband
    May 8, 2015 at 4:05 pm
    Tom, if it makes you feel better, I also found it hard at first figuring out when Soundtrack Pro had my sound print and when it was applied….
