Activity Forums Adobe Premiere Pro Best way to playback and digitize Beta SP into Premiere Pro
  • Best way to playback and digitize Beta SP into Premiere Pro
    Posted by Jesse Gift on November 22, 2013 at 9:44 pm
    I am running Adobe Premiere Pro on the iMac OSX 10.5.8.
    Here are the iMac specs: Processor 3.2 GHz Intel Core i5, Memory 16 GB 1600 MHz DDR3, Graphics NVIDIA GeForce GTX 675MX 1024 MB, only 1 Thunderbolt input.
    Can anyone suggest the best deck or combination deck and converter. It would be great to use the thunderbolt. I have not used this system to input Video via the Thunderbolt and am a little concerned.
    Any help appreciated.
    Jesse
    Andrew Rendell replied 12 years, 9 months ago 3 Members · 2 Replies
  • Gary Alan
    November 22, 2013 at 11:33 pm
    The best way is to get a Sony Betacam SP player or recorder and use the Component Betacam outputs. NOT the composite output. Probably any I/O box that has Betacam component inputs will do a good job. Like Black Magic, Aja and Matrox. You will need three identical length BNC video cables to hook them up. Plug them all into the correct connectors. Such as Y to Y, B-Y to B-Y and R-Y to R-Y. Babysit putting in the tapes one at a time and sit back while the computer records the tapes in real time. You don’t need any tape control. Meaning you can just manually start the tape playing and the software app to record on the computer. If you think you will need to reference the tapes again in the future to recapture some footage (I don’t know why since you can easily make copies of the digital files as backups), then set it up to use the timecode off the tapes to be used in capturing and to label and keep track of reel/tape numbers. I don’t know about Thunderbolt for the I/O. Maybe someone else can help with that. Also, there may be other ways and decks to use, but IMO, I this is the best and how I would do it.
    Have fun,
    Gary
  • Andrew Rendell
    November 23, 2013 at 7:02 pm
    I would think that hiring a Sony J30 with firewire would be the simplest way to hook up.
    Almost all Digibeta decks play back Beta SP tapes and a single wire SDI cable to a breakout box is less prone to errors/mistakes than analogue wiring, so I’d be inclined to go that way rather than hunting around for an older Beta SP deck.
