Activity Forums Adobe Premiere Pro Best way to pillar bar 4:3 video in a 16:9 sequence
  • Best way to pillar bar 4:3 video in a 16:9 sequence
    Posted by Mike Tomei on September 29, 2010 at 5:01 pm
    Hello all,
    I have some 4:3 video in a 16:9 sequence that I’m looking to add pillar bars to. I have a camera shot and the subject is narrating various video clips that I need to drop in sporadically and cross dissolve in and out of. I’m wondering if I should:
    1) Add a 16:9 black matte to a video track above the video track with the camera shot, then add the 4:3 video clip on a higher video track. The black matte will create the pillar bars. or…
    2) Insert the 4:3 video on the same track as the camera footage and let Premiere automatically create the pillar bars since there’s nothing on any “lower” video tracks.
    Or does it really not matter either way? Thanks!
    Mike Tomei
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
    Adobe Production Premium CS5
    Vincent Rosati replied 15 years, 11 months ago 2 Members · 1 Reply
  • Vincent Rosati
    September 29, 2010 at 5:31 pm
    It doesn’t matter, as you suspect. But as a matter of maintaining total control, you should put a black solid underneath the 4:3, or matte as you mentioned. Remember to use a legal black if this might be displayed on a CRT, not pure black.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
